Way to customize IVR forwarding for different hours? | Community
  • September 10, 2024
  • 8 views
We have a setup where there are three users that each have their own IVR option from the main IVR prompt.  E.g. press 1 for Leslie, 2 for Henry, etc.  We also have a #4 option for after hours emergencies.
We want each of the users to be able to have normal calls, directly to their extensions (1, 2, 3) to go to voicemail after hours.  But if someone presses 4, to go into the Call Queue (which we already have) for after hours.
I can't change the business hours on the users because then the emergency option doesn't forward to anyone.  And I can't change the business hours on the IVR and use say an "alternate" IVR because Zoom doesn't support multiple IVRs with the same extension.
How can this be accomplished?
Best answer by Eliot
hi nickharvey249,
Zoom provides a lot of flexibility for call routing using auto receptionist(s), IVR(s) and call queue(s).  auto receptionists and call queues themselves must have one extension and may have one or more telephone numbers.  ivr is part of the auto receptionist and does not have its own extension or telephone number.
To accomplish what you want, you could have an auto receptionist set up for custom business hours (9-5 monday thru friday), closed hours (not business hours) and holiday hours (new year’s day).
During business hours, incoming calls could be routed to your ivr, i.e. Leslie – press 1, henry – press 2 and nick – press 3.
During closed hours and holiday hours, emergency calls could be routed to an emergency call queue.  You could designate the members of the emergency call queue and select one or more members to receive calls to the emergency call queue during closed hours and holiday hours.
Please see zoom support articles below.
Managing auto receptionists (zoom.com)
Changing auto receptionist settings (zoom.com)
Creating an interactive voice response system (zoom.com)
Managing call queues (zoom.com)
Changing call queue settings (zoom.com)
EliotAnswer
September 12, 2024
hi nickharvey249,
Hi @nickharvey249!
Given the time elapsed since we last heard from you, I've taken the liberty of marking the provided answer as the solution.
Have a fantastic day!
