Zoom Phone Assistant always on top | Community
Partner
September 20, 2024
  • September 20, 2024
  • 60 views
Hello all,
I find the Phone Assintat quite useful, which hides in idle state. But when a call is active, there is no way to hide or minimize it. If you have several widgets or Speed Dial buttons, it can use a lot of space, and you have to keep moving it around to see the screen behind it (document, web, etc.).
I think it should have a minimize option to show just the call control bar during a call.
Best regards,
David
HI @drevilla
In most cases just hovering the cursor away from it it will hide it, if that doesn't help try with this:
Sign in to the Zoom web portal. In the navigation menu, click Phone. Click the Settings tab. In the Zoom Assistant - Phone section, click the Zoom Assistant toggle to enable or disable it.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0058042#:~:text=customize%20the%20widgets.-,Sign%20in%20to%20the%20Zoom%20web%20portal.,to%20enable%20or%20disable%20it.
Let me know if helps
drevillaAuthor
Partner
September 20, 2024
Hi ZoomieLo,
Assistant hides when it is not in a call. When there is an active call, it has some kind of "always on top" and it does not go to the background, or hide or minimize.
And I don't want to disable it, I just want it not to be intrusive while on call status.
Regards,
David
