Sending calls to zoom voicemail if external number doesn't answer?
mhl6
Hi, I have a single zoom line for my business. Through the auto receptionist, I set up conditional call forwarding so the call routes to my assistant's cell phone after 10 seconds.
I would like to set it up so that, if my assistant doesn't answer, the call ends with the caller in my zoom voicemail (not the cell phone voicemail). Is this possible? Or is there another way to set this up?
4 REPLIES 4
sparrow
Basically, it's going to boil down to ring time. If your Zoom phone voicemail max wait time is set to a long ring period and your cell phone voicemail is shorter, then the cell phone voicemail will answer before Zoom voicemail will. I ran into this issue with my Cisco Webex number doing the same and shortening my Zoom voicemail max wait time resolved it for me.
mhl6
Thanks for replying. I don't think this worked. I have the max wait time set as short as possible (10 seconds).
sparrow
My apologies. I didn't catch that you setup conditional call forwarding. I don't see an option to route the call back into Zoom voicemail since you're sending the call to an external number. I've seen this option on other voicemail platforms but haven't seen it in Zoom.
scheived
Contributor I
Contributor I
I'm not sure it will work in this cirumstance but when using call handing you want to turn on "Require to press 1 before connecting the call" this will prevent the voicemail from being left on a cell phone.
