  • Starting February 3, 2025, Zoom Phone customers must add their phone numbers to an approved 10DLC campaign in order to use SMS/MMS capabilities on their numbers.
  • Introducing more live support options! More Zoom customers now have access to live agent chat support. Sign in and visit our Contact Support page to see all your available support options. We’re here to help!
No dial tone or ring tone on outgoing calls
jules3
Zoom Phone users making outgoing calls will not hear a ringing tone or a dial tone. The caller does not think that the call is connecting although it is and is hanging up on prematurely, causing a lot of problems for our clients. This is happening on iPhone app, desktop softphone, using a headset, and without a headset. It's not everyone, with every call. This appears to be intermittent.
7 REPLIES 7
Hi jules3,
Please check to see that the clients and or apps are the latest versions.
It may be a network problem.  Zoom has a network connectivity tool that can be run when you are experiencing these issues.
https://support.zoom.us/hc/en-us/articles/12997935825293-Zoom-Network-Connectivity-Tool
I have the same issue described above. I did the network connectivity test and there seemed to be no issues (can provide the log).
How do I solve the missing dial tone?
Thanks Eliot, the network is working fine and the problem happens on multiple connections. We have staff all over the region working from home and in the office and it happens regardless of network. This is definitely a problem with the Zoom phone service. Any other thoughts?
Was this ever solved?  I can't get it to ring (audio tone) when dialing out.  When it just has no noise I don't know if it dialed or not?
I have the same issue. It rings fine if I unplug my headset. But if my headset is connected, it won't. Same headset for the past 2 yrs.
How do I solve the missing dial tone please?
dglasgo1
We are experiencing the same issue of no outgoing ring audio when connecting calls (internal or external), but only for 1 of our users and happens on his mobile app and desktop app!  Open to any other suggestions.
hi,
because it is only one of your users, it must be something different about the configuration for this user.
does this user use something different such as a particular brand and model of wireless headset, a different mobile device, a different version of an operating system, a different desktop and different operating system, a different version of zoom workplace app, wireless access or wired connection, etc.?
you can try completely uninstalling zoom desktop app and mobile client and reinstalling.
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0065146
