Yealink W80DM/B using W57R Cordless. How to connect? | Community
  • April 29, 2025
  • 1 view
Wanting some help with configuring the W80DM in a Mesh set up with the W80bs connecting back to the W80DM.
From what I have found on the FAQs it asks you to register the W80bs back to the W80DM. So I have completed this. But when looking to add the handsets I quickly realised that I need sip accounts for these devices? So my question is how am I meant to set this up as there is nothing documented on how to do this and yet all FAQs list the devices as supported? The W57R handsets have IPUI addresses but not mac addresses so the Alternative was to use the other device option within Zoom but that asks for a Mac address which this device does not have.
I assume I need to put the User email and password into the SIP account for this to work but I want an answer before I go back to the customer to try something that wont work
April 29, 2025
Great question! Setting up the Yealink W80DM/B with a W57R cordless handset usually requires registering the handset through the base station’s web interface or using the pairing function directly on the phone. Make sure the W80DM/B is properly configured on your network and the firmware is updated, then follow the registration steps in the manual for smooth connectivity. By the way, if you’re also setting up an office or home workspace, you might find it useful to check out a quality furniture store Lahore offers, since having the right setup can make using communication devices like these much more comfortable.
