2024-10-16 06:21 PM
I have a Polycom vvx411 and a bunch of Polycom vvx250's that all provisioned just fine. The one issue I'm having is that on the vvx411, every 10 minutes or so (or less, just a guess) the phone will show a Line:Unregistered error for about a minute, and I won't have a dial tone or phone service during that time. When I click the info button, I get a "Line Information" screen that says "Line 1: BikeShopAdmin (Not Registered)" and below it a server ending in .zoom.us that also says "(not registered 0)" and below that, a really long AOR number ending in zoom.us.
I'm actually having this issue with the vvx250's as well, where the dial tone/service is cutting out every ten minutes or so for a minute, but I don't think they're showing the "Line:Unregistered" error, but considering the symptoms are the same, I believe the root cause the be the same. If anyone has any ideas, I'm all ears!
2024-10-25 08:07 AM
We're having the same issue with Poly Edge e350s. Unfortunately, I don't have any solutions at this time. We opened a ticket with Zoom and they had us enable some advanced logging on the phone so we're waiting for it happen again so we can submit the logs. We're not having it happen as frequently as you are so we haven't been able to catch it. If we figure something out, we'll post back.
2024-11-20 05:03 AM
hi bikeshopadmin,
Because the problem exists for all your poly desk phones, I think the issue is likely a network issue, i.e. the desk phones cannot connect to the zoom phone servers on the internet.
For troubleshooting purposes, try these steps in order:
thanks, eliot
