2025-04-11 11:17 AM
When I am called the ringtone plays through both my speakers and headset. I would much prefer it rings to just my speakers and then allow me to take the call on my headset.
This is on windows desktop zoom app. The app is fully up to date.
Please advise. Thank you.
2025-04-11 01:02 PM
try unchecking "use separate audio device to play ringtone simultaneously"
Use separate audio device to play ringtone simultaneously: Select another device that will play the ringtone when you are invited to a Zoom meeting or receive a Zoom Phone call. This device will ring simultaneously with your selected speaker.
Changing settings in the Zoom desktop/mobile app
thanks, eliot
2025-04-11 01:16 PM
Good afternoon, Eliot!
Hope you are doing well.
Tried disabling the "Use separate audio device to ..." option and the result was that if I select speakers, calls and ringtones would be played through the speaker. If I select my headset calls and ringtones play through the headset.
This is not ideal as I would like ringtones to play through my speakers and everything else to go through my headset.
When my headset rings unexpectedly it makes me jump out of my seat every time. I would much prefer to have my computer speakers ring instead.
Thank you for your time.
