2024-07-31 03:27 PM
We're having an issue where a persistent spam call center continually reaches our Zoom phone numbers. They use a rotating number, so when you block one they just call from a different one. They seem to use the same one or two caller ID strings, so I was wondering if it's possible to implement some kind of rule that automatically blocks callers with a certain caller ID.
For example, let's say I get a call from "SPAMCALLS INC, 555-123-1111". Blocking this number blocks only the 555-123-1111 number, but then I proceed to get calls from "SPAMCALLS INC, 555-123-1112", "SPAMCALLS INC, 555-123-1113", etc. and I have to block them all individually. Is there a way to just block "SPAMCALLS INC" rather than the number itself?
Thanks!
Solved! Go to Solution.
2024-07-31 04:21 PM
Have you tried
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0057965
thanks. Eliot
2024-07-31 04:21 PM
Have you tried
thanks. Eliot
