2025-12-24 04:39 PM
Hello, I’m having an issue with Zoom Phone Auto Receptionist routing. If the main menu is configured so that pressing a key (for example, Press 1) routes directly to an external phone number, the call rings correctly. However, if Press 2 on the main menu routes to another Auto Receptionist (a sub-menu), and within that sub-menu Press 1 routes to External Number 1 and Press 2 routes to External Number 2, neither external number rings. Instead, the caller hears a message saying the person is not available. The same external numbers work when assigned directly on the main menu, but not when called from a sub-menu. Any solution or workaround would be appreciated.
