What's New at Zoom? Join our upcoming webinar to get you a first-hand look into some of our exciting new product and feature releases.
Register Now
Zoom Phone-Dynamics Integration
joliva
I recently enabled the Zoom Phone-Dynamics integration from the App Marketplace. I was able to get it configured and functioning. However, I noticed that the contact lookup feature isn't connecting to any of my contacts in Dynamics (for incoming or outgoing calls). I called from a test record and it showed as (Example) +1 555-555-5555 instead of tying it directly to the Contact. Seems like it might be a formatting issue since in Dynamics our phone numbers don't include the +1. Anyone know how to fix this?
1 REPLY 1
jefrancisco4
Hi @joliva. Though I can’t offer exactly what you’re after, I do have a suggestion which is to check this KB article that shows how to integrate Dynamics, to make sure you got all the configurations right. https://support.zoom.us/hc/en-us/articles/4418569296013-Using-the-Zoom-integration-for-Microsoft-Dyn...
Have any of these answered your question? If so, don’t forget to mark the reply as an accepted solution.
