2024-06-11 02:07 AM
We're currently experiencing an issue with our call queue setup on Zoom. We have it set to simultaneous ring, and it calls the agents for 30 seconds. However, after the initial ring, it doesn't call the agents again, and the customer remains in the call queue indefinitely.
Is there a way to configure the call queue so that it continually calls the extensions until someone answers? Any guidance or tips would be greatly appreciated!
Thank you.
2024-06-11 04:41 AM
hi norubit,
You can set the Max Wait Time from 10 seconds to 30 minutes, the default is 30 seconds.
After the Max Wait Time is exceeded, the call is routed as you specify in routing options.
Routing options
You can also customize how inbound calls are routed during business, close, or holiday hours; and for overflowed calls. Select one of the following options in the Route to drop-down menu, then use the text box to specify the route:
Changing call queue settings (zoom.com)
thanks, eliot
2024-06-11 05:45 AM
We have it set at 30 minutes on the cal queue and 60 seconds on the user settings.
The call queue calls for 60 seconds on each extension and then stops ringing. How could we fix this?
2024-06-11 05:59 PM
The only way i can get it to work at the moment is by setting the max time to 60 seconds and then the overflow to push the call back to the queue so it loops. This is a temp fix as it restarts the on hold music every 60 seconds.
2024-06-11 06:27 PM
hi norubit,
i was just about to suggest your partial solution to push the call back to the queue.
some users handle users and call queues in a different manner which may or may not work for you.
these users set up more than one call queue.
the primary call queue has members that are expected to answer calls within some defined amount of time, i.e. 20 seconds. calls not answered by the primary queue in 20 seconds are routed to a secondary queue.
the members of thsecondary queue are expected to answer in a defined amount of time, i.e. 15 seconds. if no one answers, the calls go to voice mail.
depending on the size of your account, you may want to contact your zoom account team and if one is assigned to your account, your customer success manager (csm). your csm may be able to suggest other options that may fit.
zoom has two products that offer more sophisticated options. one product is zoom phone power pack and the other is zoom contact center. you might consider contacting your zoom account team to discuss features and pricing.
thanks, eliot
