SOS Need set up help | Community
  • December 16, 2025
  • 4 replies
  • 21 views
Hi there, we began using Zoom phone ~1 year ago for our small business and have never been fully satisfied. I find the set up and customization of features confusing and don't have anyone else on my team who can help me with it. I would greatly appreciate set up guidance and would be happy to pay someone for their expertise. Some context on what we do and what I'm looking for:
We're a specialty auto repair shop open M-F 8:30am to 5:30pm. We field many calls a day from retail customers and individuals at other businesses we work with. Calls are typically to schedule appointments or ask for updates on repair/parts/etc.
Our General Manager is responsible for answering calls. He has a company-owned iPhone with Zoom installed on it. If he's unavailable, the calls ring through to my account.
One big problem: our GM's phone no loner has a cellular plan, so if he's not on wifi he can't receive Zoom calls. He's often on the road visiting customers and needs to be able to receive calls during those visits.
What I'm looking for:
1. Fix our GM's need to be on wifi. Do I need to also get a cellular plan? Is there a way to have cellular internet only so the Zoom phone is always accessible? Any other suggested solutions?
2. Have calls ring first to my GM and then to me if he doesn't answer after a certain amount of time.
3. Have voicemail box set up with a professional answering message.
4. Direct customers to voicemail via a professional automated message if it is outside of our operating hours.
5. Anything else to make us appear more professional to callers.
Thank you in advance.
Let me know if you’d like to set up a time.
Best
Hasanapanta
Best,
Hasanapanta
1. Fix our GM's need to be on wifi. Do I need to also get a cellular plan? Is there a way to have cellular internet only so the Zoom phone is always accessible? Any other suggested solutions?  Yes, cell phone plan needed or he has to use customer WIFI to get Zoom calls while on their site.
2. Have calls ring first to my GM and then to me if he doesn't answer after a certain amount of time.  On Zoom Admin Portal - Phone Management - Users & Rooms - User Settings 'tab' Set "When I'm busy on another call" to forward to your extension or DID and "When call is not answered" to the same.
3. Have voicemail box set up with a professional answering message.  You should have an Auto Reception or Queue with your Main Number and set the greeting on that - make sure you change the default hours from 24x7 to 8:30am to 5:00pm
4. Direct customers to voicemail via a professional automated message if it is outside of our operating hours.   Same as above, callers will call main number to reach Auto Reception or Queue and you will have the greeting set on that.  You will set the 'Closed hours' to be 5:00pm to 8:30am and you can overflow that if you want some other call handling/routing.
5. Anything else to make us appear more professional to callers.  Overflow routing to someone that can take calls even after hours if necessary.
brettahAuthor
Thank you, TysonG! This is helpful.
I manage Zoom Phone setups for a few other small business clients and have handled similar issues around call routing, mobile access, and professional voicemail.
Your use case is pretty straightforward, and everything you need can be configured.
Happy to take a look and sort it out for you.
You can reach out to me on my email here
Colin
