Repeating Do Not Disturb
ctobola
Zoom Phone users at my organization have repeating meetings every week (e.g., 1:00 - 2:00 p.m., every Monday), and they would like to silence incoming Zoom Phone calls during those times.
We use MS Outlook as our organizational standard, and it looks like the MS Office/Zoom plug-in only indicates that the person is in a meeting based on Outlook Calendar.. but does not put the phone on Do Not Disturb.
Is there a way to automatically set repeating Do Not Disturb times?
Thanks!
4 REPLIES 4
sparrow
A few things here. If your using the Zoom app and it's reading your calendar, there is a checkbox in the Zoom app for incoming calls to be hidden while in a Zoom meeting. Under settings, phone, and under incoming calls you'll see this checkbox. Now, if your using physical phones this may not work. Last I tried to enable DND sync which allows the client to sync DND to physical phones, I was told this only applies to Yealink phones and Poly would come later. As far as DND times, not that I've seen in Zoom. I was going to say maybe applying this via your business hours but that won't work because Zoom doesn't have the option of splitting multiple hours per day.
ctobola
Thanks, Sparrow.
I tried scheduling recurring Zoom meetings from Outlook. They appear as events in Zoom, but unless I start the meeting, it does not switch to DND. It would be just as easy to change the status in the app rather than to have to start a meeting every time a recurring event begins.
-Cloy
peattheparrot
agrees and there should be that you can set multiple dnd times on the computer app to
peattheparrot
there should be at you can add as many dnd times as you want in the computer app as well
