Celebrate with us2022-10-21 02:49 PM
I can't seem to schedule a recurring meeting. When I check the box for it, no options are offering for the recurrence pattern, as the instructions say should happen--I just get a message saying to check recurrence or repeat in my calendar invitation. If I go ahead, the meeting is scheduled for only one time.
Help? I'd like to stop having to send a new link each week, but I must be missing something.
2022-10-22 01:02 PM
2023-04-23 08:19 AM
Hellow; I have the same problem Cathylin has; I am using google calendar. How can i schedule weekly recurring meetings?
2022-10-22 03:34 PM
I'm scheduling from the Windows Zoom app. Once I've set up the meeting there, I select the option to add it to my Outlook calendar. But I don't even get that far, because when I select "recurring meeting," no option to set an interval comes up. And when I add it to Outlook, it's a single event only.
2022-10-22 03:49 PM
Here is my suggestion. I schedule recurring Zoom meetings using the Outlook desktop all the time at my FT job. I suggest making sure the Zoom add-in is loaded in Outlook and try scheduling a recurring Zoom meeting from Outlook. See if that works. It is a much easier experience. Please let me know if you need instructions on getting the Zoom add-in loaded to the Outlook desktop.
2022-11-01 04:04 PM
Hi--you may have missed my follow-up post to the topic. I already had the Zoom add-in in Outlook, but I do need instructions to schedule a recurring meeting. When I use the Zoom schedule button in Outlook, it launches an email notice and then opens my Zoom meeting defaults. No option is given for a recurring meeting.
2022-10-25 05:00 PM
I think I do need the instructions. I'm pretty fluent in Outlook, but when I use the Zoom schedule button there, it launches an email notice and then opens my Zoom meeting defaults. No option is given for a recurring meeting.
2022-10-25 05:01 PM
PS I already had the Zoom plug-in in Outlook--just hadn't used it.
2022-12-01 09:47 AM
Hopefully you had some success in doing what you needed to do! However, I'd like to give some feedback.
Scheduling from Zoom App
Scheduling from Outlook Zoom plugin
You can confirm if you go into your Zoom account on the web and view your upcoming meetings. You'll see either single occurrence meetings, or the reoccurring type, which will be under their own section.
Hope that helps!
2023-06-01 08:22 PM
I had been able to schedule recurring meetings using my PMI but in the past couple of months this capability has disappeared , I can still book recurring events but if I want to use my PMI I get a message stating that it isn't possible and a new unique login link and info is generated. The hack , which is a pain the back side is create it then edit the event and add the preferred PMI but this is a time suck.
