Zoom AI Companion2022-03-15 11:16 AM
Here is what I am trying to accomplish.
Solved! Go to Solution.
2022-03-15 11:23 AM
I am not sure about syncing a directory with the phones.
You mean Poly EM50, right? It works and is supported by Zoom Phone with a VVX 450.
There is guide to configuring buttons here: https://support.zoom.us/hc/en-us/articles/360040587552
It sounds like you want to program the buttons as speed dial.
Does that help?
2022-03-15 11:23 AM
Does that help?
2022-03-15 12:07 PM
Thank you BrandonS! I have been around the interwebs for this today. I wasn't using the correct verbage and that just made things even more difficult! Wow! This certainly beats having to create an XML file like the Poly tech suggested! Thanks again BrandonS!
2022-03-15 12:06 PM - edited 2022-03-15 12:08 PM
The power of collaboration!
