Discover Zoom success stories and upcoming events! Explore our Customer Success Forum & Events page.
Visit NowEmpowering you to increase productivity, improve team effectiveness, and enhance skills.
Zoom AI Companion2022-12-13 11:26 AM
How do I manually active an account that I create (inside zoom portal) with a fake email address so I can assign a number a vm to it.
I need a couple of false accounts to assign numbers to for delegation to others.
*********** will get a DID and vm, but since no such email or user exists, I can't click on activation email.
what's the solution?
Solved! Go to Solution.
2022-12-13 11:32 AM
Hi @dylanhunt
Can you have your Email Admin set up a couple of aliases on your email account? That way the invitations will come to you and you can set them up. It's a good way to see what the users will end up seeing too.
I hope that helps!
2022-12-13 11:32 AM
Hi @dylanhunt
I hope that helps!
2022-12-14 12:21 PM
Also, does it have to be a User extension? Common Area Phones can get voicemail now as well.
2023-03-21 02:10 PM
Hi @dylanhunt was @FORE-Craig @enielsen able to answer your discussion? If so, great! Suggest clicking the accept as solution button, otherwise; please share how you were able to resolve your issue. Thanks!
