Celebrate with us2024-07-26 09:36 AM
Hello. I am trying to update the outgoing caller ID to display our main number when we call out from our Yealink Phones (T46S). Our main number has been ported from our previous phone co. I have found the setting to change the outgoing caller ID for the Zoom app for each user, which worked fine, but that setting does not seem to carry through to the phones.
Is there a way to do this on the phones as well, or is this not possible? Even if I could add the main line to one of the soft keys so they could call out on that line, that would work -- but it only lets me add lines that are assigned to that user, and I can't assign the main number to everyone.
My major concern with it not showing the main number as the caller ID is that some phones are showing it as a "spam risk" since it's a Zoom number, I assume. I'm afraid people are just not going to answer our calls.
Thanks for any insight!
Solved! Go to Solution.
2024-07-27 05:51 AM
Hi factor110
For desk phones, you set the outgoing caller id number by customizing line keys.
Customizing line keys and positions settings (zoom.com)
thanks, eliot
2024-07-27 05:51 AM
Hi factor110
thanks, eliot
2024-07-29 06:29 AM
That was helpful. Thank you!
