Ready to set up and use Zoom, but aren't sure where to start? Begin with our onboarding support experience for everything you need to get started.
Get Started
Zoom Phone Issues
CRPTJG
Observer
Just installed Zoom Phone and the desktop app does not ring/no notification appears and rolls straight to VM.  Been thru the videos and training. Reviewed my settings and all appears correct. How do I fix this?
17 REPLIES 17
FORE-Craig
Participant
Hi there!
A couple of things come to mind. It could be that your status in the Zoom app is set to Do Not Disturb. See first attachment.
Alternatively, the call handing on the Zoom Web Portal for your Auto Receptionist and/or your User Profile for Phone has the Business Hours  or Route to are not set the way that you want it to work. See second and third attachments.
I hope that helps!
Craig
Craig
Thanks for the reply. I tried all three and still do not get a notification/ring on incoming calls and now my VM has been disabled.
Are you just one user on the account or do you have multiple users?
Craig
toddcarswell
Community Champion
CRPTJG, are you able to place calls from the Zoom Client on your VM?
I am able to place calls from the app on my desk top
CRPTJG
Observer
I am one user/one account.
JeremyW
Observer
Have you checked your business hours on your phone settings page?  Also make sure the Zoom Application is turned on in Call Handling.
I have checked both and they seem to be as you have described them to be - Zoom app  and business hrs all look correct
Could you post screenshots of the way your Auto Receptionist is set up, and your Personal Phone settings from the Zoom Web Portal please.!
Craig
Hope these help
ok.  it looks like you have your auto-receptionist set to go to the current extensions voicemail which would mean your auto receptionist voicemail.    you need to click edit on Route To under business hours and set where you want the call to ring during business hours.
Hi!
That helps a lot. You want to set change your Auto Receptionist's "Route to" to go to your Personal User Phone extension (not the voicemail for the Auto Receptionist).
If you can, send a screenshot of your Personal Phone settings page from the Zoom Web Portal to verify what it is doing for you.
Craig
That worked! thanks for your help. The screenshots you requested are below
Now I need to set up my VM - probably will be back for help on that as well
Yay!
Craig
BrandonS
Participant
You didn't describe how you setup the call flow in your account.  By default a one user account I think just has one phone number ring to a default auto receptionist.  Did you change that to ring to your extension and/or did you select a direct dial number for your extension that you are using?
If it's his direct number, the auto-receptionist wouldn't apply.
Under biz hours I have calls routed to the auto receptionist, so it looks to me.  I get the feeling I am deeper into setting this up and I should be
