Need Help!! Is it possible to set up a permanent zoom link.
joshua_132
I would like to use a permanent zoom link that I don't have to change for every meeting. Is there a way I can do that?
2 REPLIES 2
Comfort2022
Yes, it is possible, it is called recurring link.
you get that set up while scheduling a meeting, just click on the recurring link and you would need to set up how often you would have that meeting
Hey @joshua_132 did @Comfort2022's reply help resolve your issue with scheduling a recurring meeting? If so, don't forget to click that 'accept as solution' button!
Zoom Community Moderator
he/him/his
