2024-08-20 06:54 AM
I want to run webinars from 90 minutes to 6 hours on Zoom using Keynote. Is this possible? If so, what's the cheapest plan to do it?
Solved! Go to Solution.
2024-08-20 06:07 PM - edited 2024-08-20 06:08 PM
@bhima Hi there, you probably will want to look at a Zoom Webinar or Zoom Sessions license based on however many attendees you are expecting per session.
This page has all the info and you can use the "Compare All Features" to work out which one is best for you.
https://zoom.us/pricing/events
