Best way to run a high volume of recurring trainings that are a mix of Simulive and Live
Hey there,
I'm trying to figure out the best way for us to manage recurring user trainings using Zoom. We are hoping to move over to Zoom Recurring Events but I want to make sure that there aren't any potential challenges that we might face that I'm not aware of. We have a Zoom Events License with a 500 attendee limit and our average attendance limit is well below that so we're not restricted by that.
Current setup:
- Running ~70 webinars through Zoom across various languages. There are about 20 topics and the weekly content is always the same. For example 'Getting Started' is one.
- We currently manage our user trainings as 'Recurring Webinars with no fixed time' in Zoom
- We don't use any registration pages or emails as this is all done through Skilljar
- The only reporting or data that we pull from Zoom are the Q&A if needed, chat and cloud recording
Challenge:
- We want to convert these into a mix of simulive and live
- This means that we'll need to schedule these at set times and create a recurring event for each timezone that we run the training in (probably) and each language which when using Zoom Webinar is really messy looking (we did it this way in the past)
- It can also cause a lot of complexity as we need to ensure that the scheduled time in Zoom is the same as the one set for the event in Skilljar otherwise when attendees click to join it doesn't work
- We need to schedule additional events in a recurring Zoom easily that use the same Zoom link
Plan of action:
- Use Zoom Events instead of Webinars so that it's easier to see all the events for one topic and region in one place
- Can easily change sessions between live and simulive
Potential challenge with this approach:
- It seems like in order to add more sessions to a recurring event in Zoom you're not able to duplicate an already scheduled session and need to create another one from scratch. Is there no way around this?
- You can only have 60 sessions per recurring event. Is this for upcoming events? If I schedule 60 and 10 take place, am I able to schedule another 10 in the same event?
Would love to hear how others handle this? And check if moving over to Zoom Events is the right call!
Thanks,
Cliona
