Zoom Rooms Device Control with Logitech appliance?
digitalsuperfun
1) Will Zoom Rooms Device Control (JSON script that can control TVs and other devices) operate on Logitech RoomMate or Rally Bar in appliance mode? We would like to set them up with Tap IP but could alternatively use iPads if it makes a difference.
2) Where do the IP commands to the controlled devices come from?
1 ACCEPTED SOLUTION
bstrelko
Yes, this is possible (I'm currently running lighting, shading, and display commands for an entire floor from Rally Bars with Neat Pad controllers).
Commands are sent from the appliance/compute - so in this case, a Rally Bar/Mini/Huddle or Roommate running in Zoom Rooms provider mode. Controller does not make a difference - you can use any ZRC certified device that will connect to the appliance/compute.
1 REPLY 1
bstrelko
