2024-08-16 04:34 PM
Hi All,
I have read the documents, and connecting Zoom Phone to Hubspot CRM is straightforward. Is there anything I am missing?
I have read mixed reviews on the app, but it is improving.
I am coming to tomZoom from the Dialpad environment. That was also an app plug-and-play integration.
Solved! Go to Solution.
2024-08-17 01:05 PM
From the poster: The Zoom Phone app can be installed with one click from Hubspot. It works like a charm. Calls made or taken in Zoom are posted to Hubspot with recordings, etc.
2024-08-17 01:05 PM
