2023-11-10 07:54 AM
How can my Office Manager - see from her phone if someone put their Phone on DND? Can the BLF change ? or what are the options? We are using VVX Poly Phones.
2023-11-11 06:53 AM
hi ryanle,
zoom phone blf does not take dnd status of remote desk phone into account.
Note:
After setting up BLF, you will notice the following indicator lights for your BLF lines:
| Pattern and color | Description |
| Solid green | Phone user is not on a call |
| Solid red | Phone user is on a call |
https://support.zoom.com/hc/en/article?id=zm_kb&sysparm_article=KB0064051
according to zoom support article, the only synching done is to your desktop client and mobile app.
Setting DND on the following certified IP Phones will sync the presence state to your desktop and/or mobile client:
445HD, 450HD, C450HD
RX50
did not work for me, but maybe there is some option i need to set.
Supported desk phone features - Zoom Support
poly does support blf dnd status for remote desk phones but zoom needs to implement it.
https://docs.poly.com/bundle/vvx-ip-ug-6-4-3/page/monitor-blf-for-dnd-state.html
my suggestion is to discuss with your zoom account executive and support engineer about adding this feature. you can also, submit a feature request by using zoom.us/feedback. i think it is an excellent idea and have submitted a feature request and suggest that you do the same. in your feature request, be sure to explain why this feature will help you.
thanks,
eliot
