Starting July 10, 2024, customers must add their phone numbers to an approved 10 DLC campaign in order to keep using SMS/MMS capabilities on their numbers.
Register now for an upcoming 10DLC Enforcement Webinar.
Zoom AI Companion2022-12-05 07:35 AM - edited 2022-12-05 07:37 AM
Is it possible to forward extensions for people who left the company to other users or to just add additional extensions to a user?
I don't want to have an extension just dropping calls when someone leaves or moves departments.
Solved! Go to Solution.
2022-12-05 08:50 AM
Hi @Tim_L
A User in Zoom Phone only can have one extension as far as I am aware, even if they have multiple direct inward dial numbers (DIDs).
Is your concern about people calling into a DID?
You could remove the former employee's Business Hours, and then set the Closed Hours > When a call is not answered to "Forward to another extension".
I hope that helps!
2022-12-05 08:50 AM
Hi @Tim_L
I hope that helps!
2022-12-05 09:07 AM
Thank you, thats a great idea.
2022-12-05 09:50 AM
You're welcome, @Tim_L ! I'm glad that it will work for you!
