2024-07-18 08:56 AM
Hello, my friends!
I have been using Zoom for a short time, but there is something that is bothering me. I use Word a lot to write texts, as I work in journalism, and every time I execute the shortcut "Ctrl + Shift + C" in Word (which is a very common shortcut in Word and one that I use frequently), the Zoom window for screen recording opens and I cannot execute the command in Word. In other words, Zoom has the same command as Word. However, even with Zoom closed, when I try to execute this command in Word, I am prevented because the computer understands that the command is for Zoom, not for Word.
I would like you to help me go into Zoom settings and change this command, please, as it is greatly hindering my work!
2024-07-18 10:48 AM
Not sure which version of Zoom you are using. The latest version 6.1.1 uses Ctrl+Alt+C to record a new clip and it is only global if it has been checked. Ctrl+Shift+C is not used in the latest version of Zoom.
2025-03-03 04:39 PM
Ctrl-Shift-C is definitely used now, not Ctrl-Alt-C.
2025-03-03 04:40 PM
Ctrl-Shift-C is definitely used now, not Ctrl-Alt-C. https://i.imgur.com/WVyaTX2.png
2024-07-19 04:30 AM
Yes, you can reassign the shortcut in Zoom to avoid the conflict. Here’s how you can do it:
After you’ve reassigned the shortcut in Zoom, the Ctrl+Shift+C should work as intended in other applications for copying styles or other functions. Remember to choose a combination that isn’t already in use by another application to avoid future conflicts.
2025-05-28 06:55 PM
This is happening to me in Chrome. I do not have the zoom desktop app. Can anyone help. I cannot access the short cut settings in zoom.
2024-11-29 11:04 AM
Thank you, needed this. Nothing should be global by default.
2024-12-03 02:00 AM
This interfered with an important command in AutoCAD as well. I'll reiterate the above. "Nothing should be global by default."
2024-12-07 12:57 PM
It interferes with my work as well. I agree with the others, users should be at least notified once such a feature is introduced. I clearly wasn't, it occured automatically at some point. Bad job.
2024-12-30 04:17 PM
Problem here too, it's a shortcut for commenting/uncommenting lines of code in RStudio. Thanks for the help to fix it, also unchecked all global shortcuts from zoom via that menu.
2025-03-05 04:22 AM
It interferes with my work as well - This is incredibly intrusive. Global shortcuts should be off by default
