Original Sound for Musicians Toggle Gone
Pianonmanross
Hi All,
In a recent update, I noticed that I can no longer toggle the original sound for musicians option on the top of the main screen.  I can change it completely in audio settings, but that's a pain if I want to go back and forth during a meeting.  For instance, I teach piano over Zoom.  When I want to play something for a student, I turn original sound on.  But if I'm typing a student's notes, I don't want the clacking of the keyboard to be heard.  So before, it was really easy to toggle on the main screen.  Now it seems you can only change it in audio settings.
Anyone else having an issue with this or has found a solution like a shortcut?
Thanks.
1 ACCEPTED SOLUTION
Welcome to the Zoom Community, @Pianonmanross.
Big change! Original Sound for Musicians no longer needs to be activated each meeting. Go down to the caret ^ by the Audio button and see the ability to change sound settings there. Whatever you set should be persistent between sessions.
Ray -- check out the GoodClix website.
37 REPLIES 37
Thanks, Ray! This happened to me and I could not change it in audio settings - it was stuck ON. So I googled various sites and somehow found a way to turn it off without going into settings - but now I cannot remember what I did and it is stuck OFF - my screen says it is on but it is not. I have tried turning it off and on in settings, closing and opening Zoom, restarting my )Mac) laptop -- but my problem still persists. I couldn't play my guitar to be heard in a concert lsat night and have another one coming up next Sunday. Help!
I am seeing the same thing. It says ON  on the screen but it is not On.  I tried restarting the computer, unchecking it in audio settings and then rechecking, but I cannot activate original sound for musicians.
Did you ever find a fix? What was it?
Ray,
I just signed up for this very issue. I don't see the ability to set the "original sound" option as a default. I do still see the toggle button in the upper right of the screen.
In group classes there is always the issue of at least one person forgetting to set "original sound". It would be great to have the ability for the user to set it as the default (as you suggest has been done but I don't see that) or for the meeting organizer to set it for all participants. However, it would be still useful, as others suggest, to have the on screen toggle.
Thanks.
Thank you but it's not really a solution. It's not user friendly to have to got to Audio settings to change this . Often in meetings I have to switch it on and off many times to allow high quality then in a moment allow a student to ask a question. I will report this as a bug to zoom if you feel the same please do the same.
I need to switch between "Original Sound for Musicians" and audio filter several times during a meeting (I lead meditation classes and need the "Original Sound for Musicians" function when ringing the bell before and after sittings, but prefer to have the filter on during the meditation and during the discussion after the meditation). Switching "Original Sound for Musicians" on and off used to be very easy. How can it be done now? Having it either on or off for the whole session is not an option for me, and changing the whole audio setting each time also does not sound like a practical solution.
I guide meditations too! I just found that you can change through the upward arrow where it says AUDIO ^ (and a microphone) - then you can select Noise Removal (default) or Original Sound for Musicians. The toggle at the top was much better, but this process is better than having to go to settings all the time. Hope this helps!
Where can we give feedback to Zoom that this change is not helpful? It's very simple to toggle this setting on/off with a single click, instead of opening a menu to do it! 🙏
I agree! It was so easy just to toggle it off and on. Now I have to go into audio settings and turn off noise reduction? I still have trouble with sound when I teach singing lessons. My student's voices cut out sometimes even with original sound on or off. Anyone know the solution?
Agreed!  Hi Sammy, btw.  It's Steve Scholten from Seek.  How strange and wonderful to run into you here!
Agreed!  Hi Sammy, by the way.  This is Steve Scholten from Seek.  How strange and wonderful to see you on here...
This is not a help or good change, as many users need to switch between modes during a meeting. Instead of one click you need to do now at least three and that takes time and precision.
this is a horrible "upgrade" and makes zoom less intuitive and user friendly for those of us who actually do need to toggle on and off. this is NOT a solution!
Pianonmanross
Yeah - just wish they hadn't gotten rid of the ability to more quickly toggle it on and off.  Now it's several clicks instead of one quick click right at the top.
ajcrouch
Yes wouldn't it be great if there were a keyboard shortcut to toggle "original sound for musicians" on and off. I must turn it on and off repeatedly while teaching online piano lessons and the extra fiddling and clicking in the menus is cumbersome and slow.
chrisacton
this was a tragic update. During my meetings, I would toggle between Original Sound for Musicians during a musical number, and toggle it off for spoken word portions of the event. Now I need to leave another window open so I can switch back and forth - really clutters the desktop and adds a layer of unnecessary confusion that can lead to poor performance. It would be very helpful if Zoom gave the users the opportunity to restore the toggle at the top left corner.
vajrap
I agree with everyone that the loss of the toggle button on the main Zoom screen is a huge disappointment. I need to turn original sound ON briefly when I ring a bell to start and end a meditation (so that the full bell sound is heard, including the sound tailing off), but except for that I want original sound OFF because I don't want the sound of my HVAC system kicking on to be heard when I'm unmuted to talk. Can the convenient toggle at the top corner please be restored? It's too cumbersome to have to open and close the audio settings pane and navigate that.
vajrap
Yes, I too need to be able to toggle it on and off during a meeting depending on whether I'm giving a talk or playing a meditation bell sound. The new format is a serious encumbrance compared to the simple toggle on the main screen. Please restore that functionality.
NickA
Apparently I'm not the only one who sees this as an "update" that makes things more difficult.  They really should check with people who use it and switch often between the two before they make this kind of change.
I do mentoring for audio students and we constantly need to switch it on and off, so this is VERY inconvenient.
Bad move Zoom!!
cosylaurel
I agree it is a complete pain that original sound for musicians can no longer be toggled on and off with a click. I've recently paid for a Zoom account and this feels like such a retrograde step - please restore it to it's original, helpful functionality, Zoom!
sendaba
I have the same issue here. It is nice to have "original sound for musicians" as a default option, but there should still be an easy way to switch it on and off during sessions. I lead meditation classes too and only need the original sound when ringing the bell, but I want to filter to be on all other times. Nobody has the time to change the whole audio settings each time the want to turn original sound on or off. This really sucks.
lsnyder1421
Zoom, please return the ability for users to toggle the original sound for musicians on and off as they were able to before. Please fix this immediately. Thank you!
jenmarie
I have been using Zoom to lead meditation and yoga classes full-time since the start of the pandemic. I need access to the original sound toggle button in order to ring bells and do periods of chanting at the end of class without the hassle of having to go into Audio settings to locate the menu item each time. It's one thing to have to tolerate the relentless addition of new features that crowd the original interface (don't get me going on the AI Assistant harassment), but now to have a feature that I actually make use of *subtracted* is especially irritating. Not a happy customer.
WillCaminada
I was surprised and slightly annoyed with this update like everyone else. I just found that the easier path to turn on and off is to click the upward narrow at the bottom menu where it says AUDIO ^ - then click Original Sound For Musicians and when you want to go back to default, you click Noise Removal (default) - it's 1 more click than before but easier than going into Settings > Audio etc... - I do prefer the way it was before, on the screen at the top, easy to see, just one click, so please Zoom return to what it was! Anyway, hope this helps!
melfers
Zoom support - please change this back to allow us to toggle original sound for musicians on/off on the meeting screen like it was before. Why did you change this? I use it for my business just like many others on this thread.
Laserdude
Like many others I find this change to be a significant setback. It has permanently broken my workflow because the "accepted solution" does not work for my use case.
I use Zoom on a Mac and I use AppleScript to toggle Original Sound for Musicians on and off. Zoom doesn't really support AppleScript (it would be great if it did), but many apps, like Zoom, can be scripted to some degree anyway using "System Events" to access items using accessibility APIs. The old way put a toggle button for "Original sound for musicians" in the window that the Accessibility APIs could "click" on single command. However, the Audio button in the window controls isn't always visible and when it is not visible you can't script it. You can get around this problem in Settings by choosing "Meetings and webinars" turn on "Keep meeting controls visible" in the controls section. But it really doesn't help because the temporary menu that opens is completely invisible to the accessibility APIs so it cannot be scripted. Hence there is no way for me to use the new 2-click "shortcut" to access this setting.
Could I change the script to do this the long way by opening Zoom settings, select the audio section, select the audio mode I want and close the window? Perhaps. However I am using Zoom in the background and Zoom always puts its Settings window in front of everything else and I don't want this flashing up in the middle of a meeting every time I use the script to switch from a person speaking to some sort of musical presentation, or vice-versa.
Please either change it back the way it was or put these commands on actual menus that are available to the accessibility APIs.
In the meantime I am trying to find a way to go back to Zoom version 6.5.12.
Here here! I am in multiple online songwriting groups. You only want this on when you are playing, because it can cause echoes. Not having a 1-click toggle is AWFUL. I don't see how anyone thought this was a good idea. Ugh.
rhythmandtruth
I hope they fix this! I am a music therapist and deliver virtual sessions online and constantly need to change original sound on and off when clients share or when I'm playing live. Flow is everything and lots of time is wasted with awkward silence while I have to do extra steps to change the settings. Fingers crossed!
Rlangdorf
I’ll add my voice to the chorus of complaints here. I broadcast church meeting weekly. The toggle was incredibly important as we switch often between music and speaking. Please fix this!
As an audio and broadcast engineer I can tell you that computer audio can be very complicated. There are numerous ways to eliminate background sounds and still maintain high quality broadcasted audio. Motion picture, sporting events, and TV broadcasts (which I have done audio for) have ways to control audio noise. Even podcasts have simple ways to control it. Most of it is done with mic selection and some of it is done with gating, parametric filters, or expanders. There is free software for controlling (OBS Studio) and less sensitive dynamic mics are often used. I have even done full spectrum audio in a helicopter with an announcer where you clearly hear him and the blades in proper balance but no wind. I manage Zoom for 7 congregations every Sunday where the podium mic is also used to pickup music and singing and find that original sound gives the best speech quality. So you may want to consider making some changes to improve voice and music audio quality. You can do some research to find solutions or consult with local experts for assistance.
Good tips! I am also using OBS for broadcasting church meetings. I was using OBS scripting with AppleScript to change Zoom's audio settings when I change scenes and that is broken with the latest version of Zoom. I have reverted to version 6.5.12 until I can find another way to do this. I can see that using replacing Zoom's audio filters with some in OBS could do what I need. The biggest obstacle is that I am not using OBS audio because the OBS virtual camera doesn't support audio. I know there are virtual audio cable solutions and while they are common for Windows platforms I haven't found one that sounds promising for Macs, though I admit haven't looked in a while. Any recommendations?
Kartapurkh
Another one - I cannot understand why the toggle mode was turned off. I need to be able to switch between modes during a session. Please turn the toggle mode back on.
alanc1
The one click Original Sound toggle is also key for me.  The Audio Settings^ (click, move mouse, click), though painful, can work in some cases.  But there are others where it is too slow.  Need the one click.  How to regress to 6.5.12 (mentioned above) until this is fixed/restored?  (Hopefully quickly so am not down-level too long)
I find the new method for Original Sound to be convenient to start meetings, but VERY inconvenient for toggling during meetings. I use Zoom for worship service streaming. Since the change, it seems that switching to "default" (Original Sound Off) mode changes the gain as in the past, which is sometimes good/necessary for speakers away from a microphone or to suppress background/reverberation , BUT when switching BACK to Original Sound, the gain never returns to the original "Original Sound" level and I have to play with faders on the mixing board to get sound back under control - otherwise the audio sounds overdriven to the point of distortion. Has anyone else experienced this? In the past I found I had to make minimal if any level adjustments when toggling, but now I am seeing -10-15dB changes required to keep dynamic music (e.g. organ, soloist...) from distorting. The gain level of the "default" setting also seems to be higher than before the update.
More experience.  Switching still too slow for several cases.  But also, if I miss the up arrow ^, what happens?  I hit Audio and mute the input.  Aaargh.  Maybe I'll learn.
CarlaA
Hi Zoom Community members!
Thank you for the detailed feedback here. While Original Sound for Musicians is now persistent and can be switched via the Audio  menu, it’s clear many users who need to toggle frequently during live sessions are finding this change disruptive. We’ve shared this feedback internally and encourage submitting product feedback via the Submit Feedback process, so it reaches the product team directly.
Thank you!
Carla (she/her/hers)
Zoom Community Team
Windhorse
As many others have already said, this "improvement " is anything but.  I, too, lead meditation sessions, and the ability to toggle on and off easily, as one used to be able to do with one click of the button in the upper right hand corner, is way more convenient than clicking on the arrow on the bottom.  Also, it would be super helpful to be able to set Original Sound for Musicians as the default audio setting, which also seems to have disappeared.  PLEASE FIX THIS, ZOOM!
