2025 CMX Awards
Celebrate with us
Production Studio Scenes missing
streampipemike
I am having a problem with scenes missing when I go into my Webinar and load production studio.  Specifically it is all the scenes that us an image only.  I use the Media templates and load my image.  I save it and see it in PS.  When I start my Webinar and then load PS, all scenes are there but the ones with the image (Media Template).  Any clue what is going on?
1 ACCEPTED SOLUTION
Welcome to the Zoom Community, @streampipemike.
Without more info, the only scenario I can think of is that your installed version of Zoom pre-dates the inclusion of image-only scenes. Check your version number or simply update to the latest.
If the problem persists, please advise what operating system you’re using and its version.
Ray -- check out the GoodClix website.
4 REPLIES 4
Thanks Ray!!!  that did it.  Appreciate your help.
Hi @Ray_Harwood, I seem to be having the same problem. I've followed the steps on the article and still can't see the production studio under view. Would appreciate some help. Thanks!
CarlaA
Hi @streampipemike ! I hope you had a chance to review @Ray_Harwood's response. If it addressed your question, please take a moment to click "Accept as Solution" on their reply. Thank you!
Carla (she/her/hers)
Zoom Community Team
