zoom phone integration to salesforce
mbnation
can anyone help me understand how to integrate zoom phone with Salesforce? I have tried to find an app and logged into both zoom and salesforce and cant figure out how to perform the integration. I know its possible though.
1 REPLY 1
ZoomZoom
You are in luck as there is plenty of information at Salesforce and Zoom:
https://appexchange.salesforce.com/appxListingDetail?listingId=a0N30000000qEuqEAE&tab=d
https://support.zoom.us/hc/en-us/sections/4422146194957
Be sure to check if you are using Lightning or Classic Salesforce and check requirements.
If this answer helps you, please hit the “Accept as Solution” button.
Thank you,
ZzZz
