Zoom AI Companion2023-02-27 10:40 PM
how to acquire Zoom phone Number? do i need to buy a phone number license or do we need additional cost to acquire phone number, for example i want to call US
2023-02-27 11:53 PM
Hi Dennis,
Welcome to Zoom. Please go through this article. Depending on your country and your usage of Zoom phone, you will need to procure licenses.
https://support.zoom.us/hc/en-us/articles/360034342152-Requesting-Native-Zoom-Phone-numbers
Most licenses come with a Zoom phone number included so once you get a license ( metered, unlimited or Global select depending on your requirement), You can request a Zoom native phone number:
https://zoom.us/pricing/zoom-phone
Now, once you have a phone number acquired, You can assign it to a user on Zoom after provisioning Zoom phone, and enable International calling to make calls to US in your specific example:
Some more reading:
https://support.zoom.us/hc/en-us/articles/360001297663-Getting-started-with-Zoom-Phone-admin-
There are good and quick trainings available as well which will walk you through the process:
https://support.zoom.us/hc/en-us/articles/360029527911-Using-the-Zoom-Learning-Center
2023-02-28 12:25 AM
thanks for the reply, our zoom phone plan is pay as you go, and the scenario is aim currently in KSA and i want to call outside do i need to pay zoom or to our telecom provider
2023-02-28 01:02 AM
Hello Dennis,
if you are planning to keep existing numbers with your current telecom provider, zoom offers Bring your carrier service, which is a longer route, that you will need to initiate via a zoom support ticket.
if you are planning to buy numbers from zoom or port your numbers from your existing provider to zoom, that’s called native zoom phone setup and I described how to procure such numbers. In this case you will not need to pay your current provider.
2024-04-15 02:26 PM - edited 2024-04-18 06:50 AM
Acquiring a Zoom phone number is actually quite easy. You don't need to buy a separate license or pay extra costs to get a phone number.To get a Zoom phone number, you'll need to have a Zoom Phone license. Once you have the license, you can then assign a phone number to your account.If you're looking for a local phone number for the US, you might want to check out https://www.mightycall.com/local-phone-numbers/. They offer local phone numbers that you can use with Zoom Phone or other VoIP services. It's a great way to establish a local presence without having to set up physical offices.
2024-04-17 06:25 AM
I would just clarify what MarelyHerman said by stating that each Zoom Phone Unlimited or Metered license includes a phone number. If a business needs additional phone numbers for Auto Receptionists, Call Queues etc there is a ala carte phone number license for those purposes but is a seperate license.
