What's New at Zoom? Join our upcoming webinar to get you a first-hand look into some of our exciting new product and feature releases.
Register Now
When will completed calls appear in Call Log API
kalel
How long after a call completes will it appear in the Call Log API?
2 REPLIES 2
vikmalhi
They will appear immediately after the call has ended.
zac2021
@kalel at each time that you initiate an API call to get the call logs, it will always show the completed calls by the period parameters (from/to dates) defined in the API call. The delay will be dependent on factors like how fast your application will process the results, network performance, etc.
By default, it will output 30 records. The maximum is 300 records. See here for details on Call Logs API reference.
If you are looking for near real-time call log results, please see call log API events/webhooks for phone.caller_call_log_completed and phone.callee_call_log_completed.
Should you have more queries about Zoom APIs, we highly recommend to please post your query here, https://devforum.zoom.us.
If my reply helped, don't forget to click the accept as solution button! ⤵️
