Template to populate phone settings field
jghumphrey
I need a template example to get started. Specifically, I want to populate the Auto Provision Server URL field for a batch of new phones. This is for Yealink T5 series phones.
1 REPLY 1
Hi ighumphrey,
You might consider zero touch provisioning (ztp).  Yealink t5 series phones support ztp.  Assuming
(1) you have yealink provisioning ports open,
(2) you have zoom phone ports open,
(3) you have assigned on zoom phone each phone to its user, and
(4) you plug in the t5 series phone to your lan,
the phone will be automatically provisioned.
https://support.zoom.us/hc/en-us/articles/360033223411-Getting-started-with-provisioning-desk-phones
Please also see the zoom support articles on setting up zoom phone templates for desk phones.  One example for yealink is
Yealink
local_time.ntp_server1=ntp_server_addr
local_time.ntp_server2=ntp_server_addr2
https://support.zoom.us/hc/en-us/articles/360035817952-Configuring-desk-phone-provision-templates
http://forum.yealink.com/forum/showthread.php?tid=1492
