2022-12-13
06:48 AM
- last edited on
2023-08-09
01:39 PM
by
RN
I come from Cisco call manager background. The way it shares a line is you can "put" that line on a physical phone, anyone's phone provided they have to open space.
The line will ring on all phones that have this number. My exec assistants have their personal line need to have and the lines of two other exec's on their Poly vvx-350s.
Was under the impression that zoom allows 10 phone numbers assigned to a single user. Can't I just add the two exec lines to my Exec Asst Zoom phone?
Also, my numbers are still in "pending my port". Do the numbers have to be "hot" before I can assign them to the poly vvx-350 and have them show as line 2, line 3 etc?
The execs line should have its own voicemail not a shared mailbox. Shared lines can only dump VM to a shared line vmbox, so shared line isn't the solution.
Solved! Go to Solution.
2022-12-13 10:35 AM - edited 2022-12-13 10:38 AM
Hi @dylanhunt
Yes, once the porting is complete, you will be able to "Assign" the Phone Numbers (DIDs) to the Users. I suggest using Delegation & Assistant for linking the executives with the assistants. You can go ahead and set it up before the porting is done because it is linked by User:
Once those are set up, you can see the list of those set up in Phone System Management > Shared Lines > Shared Line Appearance.
I hope that helps!
2022-12-13 08:08 AM
Pretty sure you cannot assign numbers until the porting is complete.
One cannot assign more than 1 extension to a phone other than using shared line appearances or groups (or if an extension is in a call queue).
You can have multiple DIDs on an extension, Zoom will put each DID on a different line automatically.
2022-12-13 08:11 AM
Everyone has DID's, not just internal extensions so I should be able to add the DID's to each person once the port is complete.
the Exec's line would ring on his phone and on the two Assistant's phone since it's a DID, not only an internal extension, correct?
Hi @dylanhunt
I hope that helps!
2022-12-13 10:59 AM
Thank you so much!
2022-12-13 11:27 AM
You’re welcome!
2022-12-13 08:21 AM
Can only assign a DID to a single object i.e. a shared line appearance, or an extension, etc.
If you are not wanting to use Shared Line Appearances or Shared Line Groups, could trying using a Call Queue.
Though if the only issue you have with Shared Lines is how the voicemail for them is a shared voicemail box - perhaps you can just remove the people you don't want to have access from the access list?
2022-12-13 11:25 AM
Just noting here that Delegations are the same Shared Line Appearances
