Zoom AI Companion2022-06-20 07:58 AM
The Desktop Power User popup has started appearing for some non-licensed users and there is no 'Desktop Power User' switch under settings to turn it off.
Solved! Go to Solution.
2022-06-20 08:40 AM
Thanks for clearing that up for me. I never would have thought to look under Meeting for a phone function.
Cheers!
2022-06-21 10:10 AM
Hi @Dlemesurier ! If you found @1234567890 's reply helpful, don't forget to click "Accept as Solution" 😎
2022-06-20 08:34 AM
Do you mean the widget appearing which is part of Zoom Assistant (it does look very similar to Desktop power pack experience) ? If yes, it can be turned off 1/ By Users in their Zoom application, see settings --> Zoom Assistant or 2/ By Zoom account admin Admin --> Account settings --> Meeting. The widget appears on clients running 5.9.3 or higher.
2022-06-20 08:40 AM
Cheers!
2022-06-21 10:10 AM
