You're invited to Zoomtopia 2022! Our annual user conference will take place in the Americas on November 8-9 and in APAC, Japan, and EMEA on November 17.
Learn more about our hybrid event experienceEverything you need to work together, all in one place.
Explore Zoom One's Collaboration ToolsConnect virtually from anywhere with Zoom Meetings
Collaborate together with Zoom Chat
Call the world with Zoom Phone
Create and brainstorm with Zoom Whiteboard
Rich conversation analytics to improve sales
Send and receive messages and calendar invitations
Innovative video solutions for every meeting space.
Bring meeting spaces online with Zoom Rooms
Conference Room Connector links existing rooms to Zoom
Innovative solutions for every space
Solutions to host impactful virtual and hybrid experiences.
Find a Solution for Every EventHost hybrid and virtual events with Zoom Events
Elevate your brand with single session events powered by Zoom Sessions
Broadcast at scale with Zoom Webinars
Host and attend classes, group events, and more OnZoom
An omnichannel cloud solution optimized for video.
Engage customers with Zoom Contact Center
Deliver intelligent support with conversational AI
Zoom solutions elevate collaboration across vertical use cases.
Discover Zoom Industry SolutionsEnabling exciting new ways to teach, learn, and connect globally
Transforming client engagement and employee experiences
Improving collaboration between agencies, ministries and constituents
Connecting care, collaboration, and medical innovation
Real-time communication, anywhere in the world
Bridging the in-store and online experiences
Expert support and services for all your design, strategy, implementation, event, and hardware needs.
Global Services
Flexible subscription plans for hardware
An open platform that allows developers to build Zoom apps and integrations.
Explore over 1,500 apps in Zoom App Marketplace
Documentation for building on Zoom's platform using APIs, Webhooks, and SDKs
Resources that help developers evaluate & build with our solutions
Post your questions and get help from our developer community
Zoom Partners bring Zoom's communications platform to market through alliance, sales, and service partnerships.
Explore Zoom's technology ecosystem
Find a trusted Partner
Learn about Zoom's Partner Programs
Access marketing & sales resources
Login to the Partner Portal and click 'Learn'
Discover new ways to use Zoom solutions to power your modern workforce.
Access expert-led tutorials on Zoom products and features.
Network with other Zoom users, and share your own product and industry insights.
Get documentation on deploying, managing, and using the Zoom platform.
Keep your Zoom client up to date to access the latest features.
Download CenterDownload hi-res images and animations to elevate your next Zoom meeting.
Browse Backgrounds
2021-09-26
07:39 AM
- last edited on
2022-05-19
01:00 PM
by
Bri
I have an iPad Pro. I can barely hear the voices of the other participants even when the volume is set to the highest. But the problem disappears when I turn off the microphone setting. I don’t have this problem with my other iPad.
Solved! Go to Solution.
2021-09-27 07:24 AM
Great @Petyew
I am seen cases cause a problem a few times.
You may still want to try logging the Original Sound settings like I mentioned above. A different setting in Original Sound may affect the case being on or off. Worth a try.
Please Mark as Solution if this solved your problem.
Rupert
2021-09-26 06:49 PM
By when you "turn off the microphone setting" do you mean when you Mute yourself in Zoom?
Is your iPad in a case - if so, can you try it without the case on?
2021-09-26 11:37 PM
I didn’t mute myself. It’s either I turn off the microphone and hear the conversation normally or turn back the microphone and hear a very weak audio from the speakers.
2021-09-27 05:14 AM
Can you describe what method you use to turn off your microphone? Are you using an external microphone?
2021-09-27 05:32 AM
No. I use the built in microphone in my iPad. Using the settings/privacy/microphone link I turn the microphone on.
2021-09-27 06:59 AM
Try turning Original Sound either Off or On - depending on its current state.
This setting can be found in Zoom from the home screen of the app (not in an actual Meeting) in the Settings menu. Maybe under Meeting Settings.
However it is set now, try it in the opposite settings.
Just to see if that makes a difference might help us understand what is going on.
Again - is your iPad in a case - if so, can you try it without the case on?
Is your iPad up-to-date in iOS, and is your Zoom app itself up-to-date?
Also - are you able to test with earphones?
2021-09-27 07:05 AM
Original sound on or off makes no difference. Both iPadOS and Zoom versions are the latest. Using earphones makes no difference. I’ve not tried removing the iPad case. I will update here after I’ve done so.
2021-09-27 07:17 AM
Solved! The problem is with the case. After removing it I’m able to have a normal chat session. Thanks Rupert for your suggestion but I’m still unsure why the case is the problem because it was designed for the iPad Pro and the speakers are not blocked.
2021-09-27 07:24 AM
Great @Petyew
Rupert
2021-09-27 07:30 AM
After refitting the case the audio came out good. It must be the casing was improperly fitted the first time but I’m relieved.
