Audio issues -
Chazzcg
I have trouble hearing my students. What settings should be applied for optimum audio?
1 REPLY 1
Hi chazzcg,
Are both you and your students having trouble hearing each other?
The optimum audio settings depend on the type of audio.  For example, if the audio is only voice, then zoom’s default audio settings are what you should use.  On the other hand, if your students are playing musical instruments and or singing, then the audio settings need to be different.
For details, please see zoom support article.
https://support.zoom.us/hc/en-us/articles/360046244692-Configuring-professional-audio-settings-for-Z...
please also see zoom support article on troubleshooting audio issues
https://support.zoom.us/hc/en-us/articles/7302459648397-Troubleshooting-audio-issues
