2023-10-23 07:10 AM
I am running webinars on a regular basis as the zoom owner and always with one panelist and normally around 150 attendees. I always have a test with the panelist (in webinar mode) before the webinar but more than sometimes the sound during the actual webinar is much worse than the test (which always are good). I have so far not required any headset or mic for the panelist. What is the right set up and tech requirements to avoid the sound problem (video is always ok).
2023-10-23 07:58 AM
Just want to confirm - there are no other connections (attendees, confidence monitors, etc) near the panelist once the webinar officially starts, correct? Also, the panelist's mic is the only mic open/unmuted when the panelist is speaking, correct?
2023-10-23 08:01 AM
Yes correct.
