Zoom Phone and Yealink
LeandroPrado
Zoom Partner
Zoom Partner
Hi dears,
I need information about Yealink phones with standar SIP.
It's posible provisioning differents models that no appear in add device with zoom.
Let me know
1 REPLY 1
KSL
If you try to provision a unsupported/unlisted Yealink models, you can select "Other" type under Add Device. "Other" type may/may not be visible under pull down menu. If "Other" is not visible, reach out to Zoom Support for further details/instructions.
