Using an ATA device to PAGE via legacy paging hardware
HowieMendoza
Participant
Participant
Has anyone used an ATA device to to connect to a legacy paging system with ZOOM?
1 REPLY 1
Rupert
Hi @HowieMendoza
Zoom Phone has some certified hardware for this.
https://www.algosolutions.com/product/8301-ip-paging-adapter-schedule
https://support.zoom.us/hc/en-us/articles/360001299063-Zoom-Phone-certified-hardware
On other systems, I have certainly used ATAs with auto-answer and analog audio out to link to a paging system.
I don't know if you can get raw SIP credentials for Zoom Phone though (maybe you can). If you can, I guess this would work. It might be unsupported on an unsupported device though.  You also might need some back-end permissions.
A purpose-built paging interface does make things easier though.
