2024-05-29 05:49 AM
With auto call recording turned on,
You can change settings for the play prompt when recording has started.
You can change settings for the play prompt when recording has stopped.
There are no settings to change for play prompt when recording is restarted.
It plays the default message every time, no matter what the other audio notifications are set to.
It also does not follow the ad-hoc recording play prompt setting either.
To recreate: turn on auto recording and customize the prompts so you know it's not the default.
Also, customize the ad hoc call recording prompts to make sure they are not a part of this.
Call, hear the custom start prompt, stop recording, hear the custom stop prompt, start recording, hear the default prompt. No matter what you change any of the prompts to or even turn them off, you will always get the default prompt on restarting the recording if auto call recording is enabled.
Can we get the restart recording play prompt to either have it's own settings or utilize the when recording has started option (auto or ad hoc)?
