2025 CMX Awards
Celebrate with us
Do Common Area phones get a different license than a regular user desktop phone?
kw-it
Is there a different license SKU needed for Common Area phones in Zoom Phone, versus the standard license that gets assigned to a normal User's phone?
1 ACCEPTED SOLUTION
FORE-Craig
Expert
Expert
Hi!
You do need a Calling Package for a Common Area Phone. We are using the standard US/CA Unlimited Calling for ours. I would call Zoom Sales to see if they have an alternative plan to offer if you don't need it to call out externally or have direct inward dial number.
I hope that helps!
Craig
5 REPLIES 5
FORE-Craig
Expert
Expert
Hi!
I hope that helps!
Craig
kw-it
Thanks, Craig!   These phones do need a DID and outbound calling, so  it looks like the standard US/CA Unlimited license is what we needed.
You're welcome! There's a separate tab labeled "Common Area Phones" in the Users & Rooms grouping of the portal. They are simple to set-up. Just be aware that they don't get a voicemail box.
Craig
JeremyW
Participant
Participant
I use  the US/CA Metered plan as our common area phones don't get much use so it is a little cheaper than the unlimited plan.
imt
Contributor I
Contributor I
But, can't caller make outbound calls on those phones incurring charges?
