Zoom AI Companion2022-07-06 09:37 AM
Is it possible to have your Zoom phone only ring on your delegates phone. Not my Zoom phone?
2022-07-06 04:20 PM
Hello @tomkakita,
I would suggest that you Customize your Call Handling settings and have the following set to "Forward to another extension" instead:
While leaving the Delegation privilege as is so that they still have the ability to Place, Answer, and Pick Up Hold Calls as you see fit.
