Automatically Save Zoom Phone Recordings
HLevt
Hello!
I need help figuring out how to set up our zoom phone system to automatically save all the phone recordings to our Dropbox. We have this set up for our zoom video meetings, but I cannot seem to find any support on how to get it set up for phones. It is way too time consuming to manually download every recording. Thanks in advance for your help!
1 REPLY 1
Welcome to the Zoom Community, @HLevt.
Globally this setting is enabled here:
Be sure to select the Recording tab at the top:
The example shows the LOCK icon as "unlocked", and if you want to enforce recording for all users, you should LOCK the lock.  If left unlocked, it's enabled for new phone users by default, but they can disable it, at the user level.
Ray -- check out the GoodClix website or the Z-SPAN website.
