Best way to set up 4 separate candidate interviews with a panel of 4 interviewers
Janette1
Contributor I
Contributor I
I need to schedule job interviews with 4 candidates and a panel of 4 interviewers. Each interview will last 70 minutes with 20 minutes in between each interview. What is the the best way to guarantee success? Please help!
2 ACCEPTED SOLUTIONS
Bort,
Thank you SO much for your response.  The latter solution was what I was hoping for and you have now confirmed it can be done. Grateful to you!
Janette
I would also recommend a quick dry-run with the interviewers, just so they feel comfortable and confident in the process. Don't want to be fumbling around with controls in front of the candidates.
3 REPLIES 3
Bort
Zoom Employee
Zoom Employee
There are a few ways to handle this:
  • Schedule 4 different meetings, one for each candidate. The invite for each candidate's session is sent to/on the calendar of each interviewer. They join each session as they need.
  • Schedule 1 session for all candidates and just utilize Waiting Room to allow 1 candidate in at a time. When in the waiting room, you are not aware of any others in the waiting room with you, so there is no worry about candidates seeing/hearing/being aware of each other. The interviewers will remain for the entire session, or can come as go between each session.
Bort,
Janette
