Change settings for recording
Liljewall
Hi! I have recorded a webinar, but now I realise that the settings were "Record active speaker with shared screen" when I really wanted "Record gallery view with shared screen". Is there anyway to change this afterwards?
1 ACCEPTED SOLUTION
J-Zoom-ATL
@Liljewall Unfortunately there is no way to change this post the meeting being recorded. I apologize for the inconvenience.
If this answer helped solve your question/issue, please hit the "Accept as Solution" button below.
3 REPLIES 3
J-Zoom-ATL
TamieN
Hi Lilijewall,
I have my settings changed so I get all the files just in case they want them for post event processing from my marketing team.
These are the different views I get:
Go into Settings/Recording/Cloud Recording and select the different options.  Make sure to scroll down the page if you are going to use the file for post event processing to check the box:
Optimize the recording for 3rd party video editor
soorin
can i change recoding setting while cloud recoding? changed setting can apply at recoding webinar?
