Zoom
ChaleseKelly
I am unable to install zoom on my tablet and i don't know the reason for that,each time i try to install it from the app store it says this app can't be installed
1 REPLY 1
FORE-Craig
Expert
Expert
There could be many reasons why an app doesn't install. It may be that the Operating System for your tablet is not recent enough, or that you don't have enough free storage space to install the application. The following page on support.zoom.com lists the requirements for iPads and Android devices:
https://support.zoom.us/hc/en-us/articles/201179966-System-requirements-for-iOS-iPadOS-and-Android
If your tablet was provided by your school or employer, they may also have restrictions about installing applications; in which case I would check with the school or employer's IT department.
I hope this helps!
Craig
Craig
