2021-10-28 08:04 AM
Hey there,
Is there any way to see if there is a possible update that will allow you to search for previous texts and see the threads without having to type the persons name/number and start a new message only to see older threads. Scrolling takes too long to find the thread and scrolling lags so much its insane how slow it is just to scroll back 2+ days. Thank you in advance!
2021-11-11 12:25 PM
Hi @luisguerra44 ,
Apologies for the delay in response on your inquiry! I found this support article related to the use and available functionality with SMS: Using SMS. While I am not certain this will directly answer your question, it may lead you down the right path.
I can look into this functionality a bit more a try to get you a more specific answer. In the meantime, I also welcome any Zoom Phone experts out there to chime in 🙂.
Thank you!
Alexis
