Zoom AI Companion2023-04-17 03:03 PM
I am setting up some Poly vvx250 phones for my work with Zoom accounts. I make a user, assign the user to a phone, I then set up the phone and once the phone is set up normally it will provision and we are good to go but some of them do not and I need help on how I can provision them so they can start to use them.
2023-04-17 04:16 PM
Hi @Ventana1-
You can only assign up to 3 phones to a user. Are you saying that some phones assigned to different users do not Zero touch provision ?
If yes, Make sure your firewall ports for Zoom phone are open:
