Zoom AI Companion2021-11-16 03:53 PM - edited 2021-11-16 03:54 PM
The difference is very noticeable.
The TTS prompts are about 1/2 the volume of the default Zoom prompts.
Anyone else notice this ? is there a Fix ?
My AR has a TTS prompt, its good quality but pretty quiet
When caller presses 2 and gets transferred to Q, the initial greeting prompt is jarring and very loud compared to the AR prompt
2021-11-18 10:32 AM
We have our Greeting Prompts disabled, so I haven't noticed this but we do use TTS for various recordings. Have you played with different voices to see if the volume is difference between them?
2021-11-18 11:16 AM
I've only tested the first 2 TTS voices so far. They both were the same volume (i.e. much lower than the default prompts)
