2023-03-27 01:49 PM
Hi everyone! We're new to Zoom Phone and have what may be a rudimentary question. Here is our situation:
So, with all of this in mind, do both employees need their own assigned phone number in order to actually use Zoom Phone? Or would they be able to make and receive internal and external phone calls using only a call queue for the main company number (plus dial-by-extension for internal calls)?
Or does each person require their own direct phone number in order to make/receive external calls?
Thank you for your help!
2023-04-10 12:20 AM
Hello @cody-fully
Not sure if you have received your answer yet.
Answer: they do not need their own phone number, They can use the call queue's id as their outbound caller id and can make ext to ext calls as well
answer: They will receive calls on behalf of the call queue since they do not have their own phone numbers. So make them part of the call queue so when someone calls the number, they both are notified and can answer the call
2024-12-28 11:40 AM
Great explanation, thanks.
2024-05-07 11:50 AM
Hello.
I would like to ask a further question along these lines.
Now, if you took the exact situation above but threw a Receptionist into the mix that would answer the initial call to our office instead of having the users extensions ring when the main company number is dialed, then could the Receptionist transfer the call to a user who doesn't have a phone number assigned to their their extension?
2024-11-15 06:43 PM
Is anyone able to provide an answer to this question?
